M: Autodiagnostika seade - ELM327 Bluetooth OBD2
marko002
#1 Postitus Postitas marko002 » K, 08 Juun 2016 19:14:33 +0300
Uus autodiagnostika seade
asub Tallinnas ja mujale liigub postiga
hind 15 euri
ühendust saab PS teel või tel 56791733
Features:
100% brand new and high quality
Read diagnostic trouble codes, both generic and manufacturer-specific , and display their meaning (over 3000 generic code definitions in the database).
Clear trouble codes and turn off the MIL ("Check Engine" light)
Set the maximum number of responses to obtain
Remove spaces from ECU responses (to speed data transmission)
Store a unique identifier in EEPROM
Set the CAN mask and filter with one command
Easily switch between variable and fixed CAN message lengths
Send CAN remote frames (RTRs)
Display current sensor data, including:
Engine RPM
Calculated Load Value
Coolant Temperature
Fuel System Status
Vehicle Speed
Short Term Fuel Trim
Long Term Fuel Trim
Intake Manifold Pressure
Timing Advance
Intake Air Temperature
Air Flow Rate
Absolute Throttle Position
Oxygen sensor voltages/associated short term fuel trims
Fuel System status
Fuel Pressure
Many others...
Specifications:
Works for Windows98/ME/2000/XP/Vista & 7
Bluetooth paircode: 1234
Main Control Chip: PIC18F2480
Color: Blue, Black
Dimension: 69 x 44 x 24mm
Package Includes:
1 x Mini ELM327 Scanner
1 x CD-ROM
