2015 WRX STI
2015 WRX STI
Sellest on varem juttu olnud, et STI saab oma platvormi, kui see jutt nüüd tõsi on, siis võib tulemus kyll hea olla. Sellisel juhul võivad need WRX concepti proportsioonid täitsa samaks jääda
WRX STI gets a new suspension layout
According to the report, Subaru has designed the new suspension layout and it will be called their new “Axle Forward Layout” (AFL). But the new layout isn’t really that new. Subaru originally unveiled it on the Exiga concept car at the 1997 Tokyo show. Subaru has had the new design in the works for over 15 years. And the new WRX STI chassis will get some major revisions for 2015.
How will effect driving dynamics on the new WRX STI? The Motoring.com.au report went on to say that the primary difference between Subaru’s current all-wheel drive layout and the new AFL, is the positioning of the clutch and front differential. Subaru engineers were able to relocate the front axle and it’s now positioned further forward effectively allowing the clutch and differential to switch places.
Improved weight distribution
Subaru has always had very good weight distribution because of the Boxer engine in the WRX STI, but this new positioning allows the engine to sit lower and further back in the chassis, making for even better front-rear weight distribution than before. This should give the new performance model even better handling in the corners.
A longer wheelbase and braking system
This modification has allowed Subaru to lengthen the wheelbase which also helps improve driving dynamics with a revised suspension and will also enhance space inside the cabin. The new 2015 WRX STI will also get a new torque distribution function. It will come fitted with an additional torque distribution set-up that independently adjusts brake pressure on all four wheels.
The Australia source says the new braking system electronically manages and restricts torque being fed to the inside tires when turning into a corner. This will effectively reduce understeer by pulling the car into the corner and improve the WRX STI’s cornering ability.
New WRX STI with less power?
What will power the new 2015 WRX STI? According to Motoring.com.au, the new performance Subaru will come with a revised version of the current 2.5-liter turbocharged four-cylinder boxer engine. It will get some tweaks to give the new 2015 WRX STI a power output of 224kW (300 hp) and 393Nm (290 lb ft of torque). Yes, that’s less than the current models 305 hp, but with the new chassis and suspension, it looks like Subaru will primarily improve performance with the new setup underneath.
Subaru has also given the STI extra underbody rigidity enhancements that will also improve the STI’s cornering ability and take it to new levels not seen in the outgoing model. They are also likely trying to meet new emission standards with the revised, and likely more efficient 2.5-liter boxer engine.
Look for the new-generation 2015 Subaru WRX STI to get a more aggressive body kit over the WRX, including a more prominent rear wing and wider body panels. Stay tuned as we’ll have to wait until January to get more details on the 2015 WRX STI.
Re: 2015 WRX STI
Nii kurb kui see ka pole ei ole uus STI uue AFL tehnoloogiaga vaid ikka see sama vana, mis on aastast 1989. Ehk siis olulist edasiminekut juhitavuses pole oodata. Tõenäoliselt tehtud jäigemaks nagu WRX et jätta inimestele tunnet, et on teravam.
- airfrance1
Re: 2015 WRX STI
Juba 13-ndal jaanuaril saab lõpliku vastuse, et milline ja mis näitajatega uus STI välja lastakse. Ainult kaks võimalust ongi: Fail or Win
Impreza WRX/STi Wagon MY06
- airfrance1
Re: 2015 WRX STI
JP uploadis siiski tõese pildi uuest STI-st, seega saab juba esialgseid järeldusi tegema hakata. Paistab, et välimuse koha pealt on STI-l lihtsalt uus suur tiib, kuldsed veljed ja teine iluvõre. Internetiarvustused tembeldavad uue mudeli juba EVO X koopiaks. Eks see vastab ka tõele. Ja jällegi on veljed liiga väiksed. Sportmudelitel on 17" veljed juba ajalugu, teistel ammu 18", 19" ja 20" all.
Re: 2015 WRX STI
mulle ikkagi meeldib, meenutab seda
Re: 2015 WRX STI
Sarnasusi leiab küll, tule stange ja kapoti jooned, taga spoiler ja koopalaiend
- airfrance1
Re: 2015 WRX STI
Minu paha, aga näevad ikkagi veidi väiksed välja vähemalt mõne pildi pealJP kirjutas:need on 18"
Ja swrt, hea võrdluspilt.
Re: 2015 WRX STI
Ja subaru vs evo mõlemal tundub sarnasusi rohkem olevat .
4 ratast , mõlemal on peeglid , klaasid ees , ukselingid , jne jne antud piltidel isegi värv . :p
Kõige parem sarnasus on see , et need mõlemad on autod :p ja turbokad .
Re: 2015 WRX STI
(Legacy 2007 2.0 121 kW 5-mt)
Re: 2015 WRX STI
Ei noh, kobe pill mulle meeldib.
Re: 2015 WRX STI
+1swrt kirjutas:Ei noh, kobe pill mulle meeldib.
Re: 2015 WRX STI
Mina teiega ei ühine - STI robustsus puudub, samuti tundub, et tehakse asju kuidagi moodi, mitte enam entusiasmiga. Antud auto on ilmselt kiire poes käimise käru.88valve kirjutas:+1swrt kirjutas:Ei noh, kobe pill mulle meeldib.
Tehnikast ka kusagil juttu on, mis seal sees ja küljes on?
ja mida need " +1 " -ed tähendavad? Viimasel ajal igal pool need koodid, samuti ei tea ma mida se " IMHO" tähendab - mingi subaru keel?
nelivedu auto ilu
Re: 2015 WRX STI
kahjuks tehnika kohta veel infot ei ole, kuid eks see saab selgeks peale Detroidi näitusthuviline7 kirjutas:Tehnikast ka kusagil juttu on, mis seal sees ja küljes on?
+1 - et mina olen samal arvamuselhuviline7 kirjutas:ja mida need " +1 " -ed tähendavad? Viimasel ajal igal pool need koodid, samuti ei tea ma mida se " IMHO" tähendab - mingi subaru keel?
IMHO - http://et.wiktionary.org/wiki/IMHO
Re: 2015 WRX STI
IMHO - In My Humble (Honest) Opinionhuviline7 kirjutas:Mina teiega ei ühine - STI robustsus puudub, samuti tundub, et tehakse asju kuidagi moodi, mitte enam entusiasmiga. Antud auto on ilmselt kiire poes käimise käru.88valve kirjutas:+1swrt kirjutas:Ei noh, kobe pill mulle meeldib.
+1 - nõustutakse eelpool kõnelejaga
Aga autost ka - mitte mingeid emotsioone ei tekita
Forester XT 2014
