2006a impreza rooli võimupump undab
hns555
Re: 2006a impreza rooli võimupump undab
#16 Postitus Postitas hns555 » E, 06 Apr 2015 10:25:38 +0300
Mul sama probleem subaru outback 2007, nagu eelpool öeldud võimalik, et lihtne tihendi viga. Igal juhul soovitatakse see enne ära vahetada kui uus pump panna. Youtube täis antud teemat.
Mõned lingid:
https://www.youtube.com/watch?v=4tTYrdzSZGk
https://www.youtube.com/watch?v=GnvnAOc07MI
Tundub et võiks sobida selline jupp: (allikas http://forums.nasioc.com/forums/showthr ... ?t=2127419)
1) Originaal osa: Subaru part number is 34439FG000.
2) Või: Dash Number 014 is the ring that easy to get to on top of the pump ( ~16mm OD x 11mm ID x 2.5mm thick)
3 - AS568A Dash Number 014 O-Rings (that's three total for full replacement)
O-ring materials known TO WORK rebuilding this powersteering pump:
Buna-N - Used in all OEM pumps. Inexpensive and will last as long as OEM ones.
FEP Encapsulated - Upgraded materials with upgraded prices. Better than Buna-N
Ehk siis: AS568A FEP
