Uus autodiagnostika seade
asub Tallinnas ja mujale liigub postiga
hind 15 euri
ühendust saab PS teel või tel 56791733
Features:
● Support Bluetooth output protocol.
● High-quality wireless scan tool, support all OBD2 protocols.
● Work with all OBD2 compliant vehicles.
● Enable to read diagnostic trouble codes.
● Small Bluetooth interface with a 16 pin socket.
● Support different kinds of devices to use this scan tool: Android system phones, Symbian system phones, Windows XP and WIN7 32bite computers.
● With turn on / off power switch.
● Read diagnostic trouble codes, both generic and manufacturer-specific, and display their meaning (over 3000 generic code definitions in the database).
● Remove the fault code, and close the engine fault alarm indicator.
Display Current Sensor Data Functions:
● Engine RPM
● Calculated load value
● Coolant temperature
● Fuel system status
● Vehicle speed
● Short term fuel trim
● Long term fuel trim
● Timing advance
● Intake air temperature
● Air flow rate
● Absolute throttle position
● Oxygen sensor voltages / associated short term fuel trims
● Fuel pressure
Model: CY - B11
Special function: Bluetooth output protocol
Voltage: 12V
Color: Black
Material: Plastic, Electronic components
Data measurements: air flow rate,air intake temp,calculated engine load,engine coolant temp,engine temperature,fuel consumption,fuel pressure,fuel trim,oxygen sensor voltages,RPM,timing advance,Vehicle speed
Supports OBD2 protocols: ISO14230-4 (KWP2000),ISO15765-4 (CAN),ISO9141-2,J1850 PWM,J1850 VPW
Output Protocol: Bluetooth
Baud Rate: 9600 / 38400
Package weight: 0.053 kg
Product size (L x W x H): 4.80 x 3.20 x 2.00 cm / 1.89 x 1.26 x 0.79 inches
Package size (L x W x H): 12.00 x 10.50 x 3.00 cm / 4.72 x 4.13 x 1.18 inches
Package Contents:
1 x Bluetooth V2.1 Auto Diagnostic Scanner Tool
1 x CD Driver
